you might think this is funny
Old Sep 22, 2002 | 02:33 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I was out messing around with my fan the other day. I have it wired to a switch and it keeps burning them up so I figured I would see what I could do to make it have less amperage going through it and in the process I wired it to an accesory fuse that wasnt in use. It worked great untill I tried to turn the car off. I think it was backfeeding through the ignition switch because it kept running untill the fan stopped spinning.
Old Sep 22, 2002 | 03:33 PM
xmind2006's Avatar
Car: '86 Iroc-z28
lol
That is pretty funn when you find those little quarks.
Old Sep 22, 2002 | 04:59 PM
meridius's Avatar
I think what was going on was that the fan was actually creating a current and backfeeding through the circuit to the ignition. The little current it created was enough to keep it running though , I was kind of surprised at it though.
Old Sep 23, 2002 | 07:17 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
You provided a second voltage source for the ignition. The internal motor windings are very low resistance. I would have loved to have scoped the voltage, can you just imagine all the noise those brushes generated on the 12 volt line. Amazing
Old Oct 10, 2002 | 01:54 AM
86LB9's Avatar
Can you start the car by cranking over the fan?? lol
Old Oct 10, 2002 | 09:42 AM
MdFormula350's Avatar
thats funny, but i am sure if it happened to myself i would not be laughing...
sounds like you should hook the fan up by just grounding the relay... so you dont have to worry about using fuses/ high output switch..
Old Oct 14, 2002 | 09:25 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I did the same thing several years ago. Just get a relay and it won't happen anymore.
ex-x-fire
Jan 12, 2024 01:58 PM
Fronzizzle
Mar 18, 2019 08:29 PM
SlowCamaro88SC
Nov 5, 2001 04:26 PM
lazyano
Mar 30, 2001 11:29 PM
