What are these connectors?
Old Nov 4, 2001 | 12:14 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I found two connectors during my engine swap that I need to know what they are. They're located up near the firewall on the passenger side near all the AC stuff in that wiring harness. There's two connectors. One is a two wire connector, one wire green, the other black. The other connector is a single wire connector with a red wire. The connectors are a long type connector, not like most of the shorter connectors on the engine. The reason I need to know what these are is because the red wire connector looks quite fried and the two wire connector has some melted spots on it which I figure is from the fried red wire. Any help would be greatly appreciated. Thanks in advance.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech hot coil.
Old Nov 4, 2001 | 12:46 PM
Vader's Avatar
86,
The dark green wire is likely power to the AC compressor clutch, and the black wire in the same connector is the clutch ground.
The single red wire could be the AC HIGH fan relay power feed, or could be the power to an underhood lamp.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 4, 2001 | 03:39 PM
<font face="Verdana, Arial" size="2">Originally posted by Vader:
86,
</font>
Thanks for the help. I hope that's all they are. My AC has basically been eliminated and all the cycles work for my heater so if that's it then it's no big deal. I don't have an underhood lamp. Never did have one since I've had the car anyway. So I guess if that is what it used to go to then that's no big deal either.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
