cooling fan wiring question
Old Nov 9, 2001 | 12:33 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I understand that the 4th gen fans are wired to run in series when they turn on, then when the temp threshold is met, they go to parallel. Any advantage to running this way instead of single full speed first, then both ? Any disadvantage besides another relay?
Old Nov 9, 2001 | 10:15 PM
Vader's Avatar
Afgun,
The advantages I can think of would be:
More even airflow across the entire radiator;
Slower fan speed at lower temperatures (somewhat of a poor-man's variable speed);
Softer fan motor starts providing less wear on the bearings, brushes, commutator, etcetera;
Lower power consumption (I=E/R);
Quieter operation.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
