Ignition popping
Old Nov 12, 2001 | 12:27 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Ignition popping
I recently put a 350 with a comps cam, power band 1500-5500, 4.10 rear end, converted the camaro to carb. My question is I have a summit ignition coil, thats suposed to put out 60,000 volts, and its for a points igntition which is what I have. Now everytime I get on it down the track it starts making this poping sound usually around anywhere from 5-6 grand. Causing me serious time in 1/4 mile, I pull 1.9 60 ft times but can only get 14.6s for my time. Im wondering if my points are the cause for this poping, if they cant handle the high rpms. Thanks for any help
1991 teal camaro RS rebuilt 96 350 marine motor, comp cam, accel ignition,8mm accel plugs and wires, hedman headers and y-pipe, and rear end with 4.10 gears. Stock 700r4, best 1/4 time 14.6
Old Nov 12, 2001 | 02:46 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You can shelve that point ignition any day now... This is the year 2001 of the new mellenium. We have beauti new invention.
It's called the transistor..... Just kiddin'
Assuming your plugs wires and cap are in good shape. Try replacing the points with accel medium tension points. Replace the condenser too. Your "60,000v coil" may be
creating too much voltage for your cap to distribute (cross fire). Try adding a ballast resistor {approx 2 OHMS}(accel, chrysler) to the + connection to reduce current to the coil.
This will increase the life of your points and reduce cross fire. (exessive voltage)
Check the distributor shaft for side to side wobble. Some Accel distributors seem to wear quickly here. Make sure the timing isn't over advanced (32 to 36 total @ high rpm.)
Do not run "hot" stock heat range plugs at the drags They will overheat and glaze.
If you normally use AC-R45TS, go to
AC-R42T(S) or champion RV8C. Hope this helps.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
