what is wrong?
what is wrong?
my alternator and battery are new, the alternator isnt giveing the battery a charge, what can be wrong, where do the altanator wire go, do you think its a bad ground, pleae i need your help
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
come on anyone
The wire going between the alternator and the battery has a fusible link in it. It may go down to the starter and back up to the battery. Haven't checked on the 3rd Gen's. Anyway the fusible link keeps the alternator from overcharging the battery in the event of a runaway voltage regulator failure. You can run a 14 gauge wire directly from the back of the alternator to the battery positive terminal. The 14 gauge wire will burn thru just like a fusible link if the alternator fails but will ensure positive charging. Good Luck!
87 TA, 305 TPI, Custom CAI, K&N, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler, 160* thermostat
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
