Question about replacing tail light bulbs.
Old Nov 13, 2001 | 05:51 PM
blkform88's Avatar
I tried to replace my left(drivers side) break lights yesterday and failed. I could get at the lights but my problem was geting a good secure connection between the bulb and socket. The bulbs are in, but loose. They go on and off with the slightest touch. Is there a trick to locking the bulbs in place. They are T2057. Sorry for the dumb question, I'm a rookie.
Old Nov 14, 2001 | 02:14 AM
Jza's Avatar
Jza
Push it in (should feel springy) and turn clockwise. If you did that and it's still wobbly, you can either try and bend the "spring" contact back up, or go to a junkyard and grab a bunch of the bulb holders from a similar car.
Old Nov 14, 2001 | 02:15 AM
Jza's Avatar
Jza
By the way, it's only gonna turn a little bit (about 15 degrees), not screw in like your every day household bulb.
Old Nov 15, 2001 | 12:25 AM
Kandied91z's Avatar
also, try to install it using a piece of cloth; finger oil can shorten the life of your bulb!
Old Nov 15, 2001 | 01:46 AM
Jza's Avatar
Jza
Halogen bulbs, yeah. Taillights are incandescents...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
