HELP, My dash lights will not work after bad cd install.
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
I was trying to hook up a new cd player to my 91 bird and I got a few unwanted sparks from the wiring harness (for the cd player) then my dash lights did not work. My gauges still work, but no lights. My driving lights work also. Also, I checked the fuse box and everything is good, so what could it be?
Thanks a lot for any info!
The new project car!
1991 Pontiac Firebird
How did you check the fuse's did you pull them out or check with a meter. If you have a meter did you check continuity or just voltage? A blown fuse doesnt always turn black and have a visible break. Does your dome light still work? Replace the radio and illumination fuses even if they look dont look blown. Jered
The_Phoenix
Feb 4, 2016 07:10 AM
