help courtesy lights fuse keep blowing
Old Nov 14, 2001 | 10:08 PM
ZKlynt's Avatar
my 86 z28 has been sitting for about 1 1/2yrs then couple of weeks ago, i decided to get her running again, and since then the courtesy light keeps blowing, i tryed every differnce size fuse made to see if any would work, and the 15watt fuse held it for about 1wk and now once again none will hold, and i cant figure out what is wronge, any help would be aperciated
thanks very much
Old Nov 15, 2001 | 12:23 AM
Kandied91z's Avatar
first of all you should have the right fuse in it; but i'm not sure what it is so i can't help there.
secondly, sounds like you have a loose wire somewhere; i would check the connections on any accessories like the radio and such you are using. the circuit itself is usually pretty dependable, either someone tapped into it with an external accessory causing your problem or your working on something electrical in which case you should know what is causing your problem.
good luck.
Old Nov 15, 2001 | 10:54 AM
mtccl's Avatar
Definitely a grounding problem. Lots of stuff is wired to the accessories fuse that the courtesy light is also wired to. The most common place is the radio and the wiring associated with it. Aftermarket installations are famous for causing grounding conditions. Have you had any dash panels off lately? Check behind those if you have.
87 TA, 305 TPI, Custom CAI, K&N, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler, 160* thermostat
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Old Nov 17, 2001 | 08:18 PM
JAY87GTA's Avatar
Try checking if anything fell inside the cigarette lighter and/or remove the lighter, it might be shorted.
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Nov 18, 2001 | 01:32 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
<font face="Verdana, Arial" size="2">Originally posted by JAY87GTA:
</font>
I second that. My cig. lighter was rusted over, and it caused my fuse to blow constantly. Try taking the lighter portion out and seeing if your fuse still blows. If it doesnt that is your problem. If it still blows, try unplugging the harness behind the lighter, it snaps right off.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
GTAman
Mar 15, 2019 11:40 AM
Omega
Aug 10, 2015 12:46 PM
