blacklight wiring
Old Sep 28, 2002 | 03:39 AM
FU-Q's Avatar
blacklight wiring
i plan on having two 12" blacklights one by feet of driver, one by feet of front passenger. and one 12" right behind the pass. seat.
whats the best power source? what kind of switch? does anyone have a wiring diagram?
i plan on getting those autozone blacklights that plug into the ashtray, cut the plug off.
is there a better way of doing this?
Old Feb 21, 2011 | 09:01 PM
msstapleton's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Factory 700R4 Auto
Axle/Gears: dunno
Re: blacklight wiring
I am planning to hook at least a 18" or bigger bulb onto my T-Top brace in ceiling. Then get a plain white shirt on and drive around at night. Spooky!!!! hahahahahahahahaha.
I will let you know my wiring switches and how to hide it from the cops also. YEA!!!!!!!
Old Feb 22, 2011 | 12:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There should be a place on your fuse block that has the letters LPS (lamps) beside it - looks like an empty fuse slot, but it only has one hole (fuse has two prongs and thus needs two holes). That is a power source that only gets power when the lights (headlights) are turned on.
Old Feb 22, 2011 | 05:35 PM
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: dunno
Awesome, Aint there a i plug fuse on market or just remove the fuse block mounting and pull the wire and use a quick connect on it??
Thanks for information
Old Feb 22, 2011 | 05:42 PM
Car: 1992 RS
Engine: Carbed 350
You don't do either. There is an open slot - holds a standard 1/4inch male spade connector - crimp one on the power wire for the light, and stick it in the fusebox slot marked LPS. Ground the ground wire for the light anywhere metal.
Old Feb 22, 2011 | 10:03 PM
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: dunno
ok great i needed the better understanding. I will get that once I find a bl tube cost effective. Thanks
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
