Blower fan
Old Nov 17, 2001 | 07:40 PM
Loki1199's Avatar
Blower fan
Hello again,
I looked around the board and I think I am the first to ask this. Since I removed my A/C my blower has not been working. I printed out the wiring diagram for the unit and all the wires are hooked up as they should be. I tested the high speed relay, it's ok. Getting 12 volts to the blower. Just installed a new switch to fix the problem, no luck. The restrictor thingies are getting juice - I tested those too. The blower doesn't work on any setting. I hard wired it and it blows just fine. Any ideas?
Old Nov 19, 2001 | 02:35 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Try grounding the motor to the chassis.
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Nov 19, 2001 | 06:35 PM
Loki1199's Avatar
Hi Tim. I just don't know what to do. Nothing gets juice anymore. The purple wire leading to the blower motor has a constant coltage of like 2 now. The red wire going into the high speed realy has a constant of about 13. Still, the blower works hard wired. Short of ripping everything out and starting over, what can I do?
Thank you for your patience. Electrical is the bane of my existence
Old Nov 19, 2001 | 07:12 PM
BlueAlice91bird's Avatar
I had a blower once that cut on and off and I just replaced. Perhaps thats what you need to do.
I too am having troubles with my blower right now, only mine won't turn off, wanna trade.
Anyway I just was gonna ask how to check the switch or the relay, and how to get the switch, part number?
Good luck on yours, and thanks if you can help
Old Nov 19, 2001 | 09:00 PM
Loki1199's Avatar
It works!!!!! My roomie came out and gave me a hand and after hours of testing (not including what I had already done) we figured out the problem. A burnt out high speed relay and a popped fuse. Apparently I had blown it while trying to get the blower to work. We found out about the fuse by testing the brown wire that runs to the HVAC unit itself. Made me feel dumb. So, all speeds but high work. No big deal.
As for part numbers, sometimes they are written right on the relay or switch. Also, they disconnect really easily, so just bring it with you to get the new one for a quick comparison.
It sounds like your switch is messed up, if it's staying on all the time. Or maybe your high speed relay is stuck in the GO position. Good luck. I'll try to help out if you have more questions. Tim the moderator is the man when it comes to this stuff though.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
