Messed up GTA radio controls
Hey, I think I need to replace the turn signal switch inside the steering column. it's hard to explain but it's the little white piece of plastic with about 4 metal spring loaded pins that keep electrical contact with the steering wheel when you turn the wheel. Anyways, I used a screwdriver when I was trying to tighten the steering wheel up and accidentally touched two of those pins, which resulted in shorting out something. What I'm wondering is, if I get a turn signal switch thingie from another GTA, will it work, or do I need the radio from the other car too, since I know there's like a theft prevention mechanism somewhere in there.
[This message has been edited by Mike89GTA (edited November 22, 2001).]
colton_carlson
Mar 8, 2019 12:21 PM
The_Phoenix
Feb 4, 2016 07:10 AM
