Brake light switch wire and others
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I can't find the brake light switch wire. There is a gizmo that has 3 connectors on it. 2 of the 3 have no effect on the brake lights. Who knows the wire that activates the light?
I also can't find the neutral safety switch wire. I have read on here that its the yellow one...well, there is no yellow wire in the shifter assy. Which one do i tap into!?
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I can't remember the exact color.But go to the switch at the brake pedal assembly under the dash.It is the only wire that will be hot only when the brakes are pressed.And if no one responds before I get back from the shop tomorrow,I will let you know what color the safety switch wire is.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
'91 RS, 375hp 350
Omega, what year thirdgen is this? The wiring may vary SLIGHTLY from year to year.
For the brake light, you will find a switch above the brake pedal. Orange is hot all the time, blue gets 12V to the rear brake lights when pedal is depressed, and yellow gives 12V to the high mount third center lamp, if so equipped.
For the wires at the Park/Nuetral Safety switch, they are:
Dk Green/White - gets 12V from starter relay
Purple Wire - Gets 12V from Dk Green/White ONLY when in neutral, going to starter
Orange/Black - neutral input for ECM
Blue - Gets 12V from Turn-B/U fuse (20 amp)
Lt Green - gets 12V from blue wire, goes to backup lights ONLY when shifter in reverse.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Engine: LS1 / LS3
Omar, you are a GREAT help, i appreciate it.
I am working with an 89 Formula.
The brain looks for a ground for when the NSS is activated. I don't know if the purple wire will give that and i am not to thrilled about it receiving 12V when the car starts. Would the orange/black wire be the correct one to tap into in order to get the ground when the NSS is activated? I probed around but i couldn't find a suitable wire from that harness. I have it bypassed at the moment, but i was just reading that some guy did $2000 worth of damage because he couldn't be arsed to hook it up right.. i don't want to follow suit.
I think i have the brake light figured out, i will test it once i get the VATS taken care of.. do you know where and what colour wires i am looking for? My manual doesn't have any information on it. The only location info i have found is that it is behind the dash and "hard to get to"
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
