hypertech thermostat switch
Old Oct 1, 2002 | 10:39 PM
slow91z28's Avatar
I just ordered one and it came in today and i was wondering how to install it? any help would be great. Thanks.
Old Oct 2, 2002 | 01:00 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Depending on how fast you are, you might want to drain out (some of) your coolant.
Take the old fan switch out of the passenger side head, between cyls 6 & 8. Put in the Hypertech switch. Cut the old terminal off the wire, strip back the insulation of the factory wire you just cut, then crimp on the new supplied terminal and plug into the switch.
If you think you can swap the switches fast enough, there's no need to drain any coolant although you'll still loose alittle.
Old Oct 2, 2002 | 11:27 AM
82-T/A [Work]'s Avatar
It may not be necessary to strip and cut the wire... some new kits come with an adaptor wire. Use that first if possible.
Todd
Bubbajones_ya
Jul 6, 2024 08:32 PM
tglennon11
Sep 23, 2015 05:30 PM
Stryker412
Sep 20, 2015 06:59 PM
Randomtask2
Sep 10, 2015 08:37 AM
85Special
Sep 3, 2015 04:21 PM
