gas gauge always on full. What to do?
Old Oct 3, 2002 | 09:38 PM
JDV's Avatar
JDV
My gas gauge is always on full.It never moves any more. Is there some way I can check the sending unit without droping the tank?
Old Oct 4, 2002 | 09:43 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
The wire(s) that come from the sending unit to the gauge are probably broaken. Happened to me once, the wire was under the car near the gas tank. Dont know if thats the place you will find yours, previous owner did a lot of custom (stoopd) work on the car.
Hope this helps.
Old Oct 5, 2002 | 09:16 AM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
the sending unit may have gone bad as well. I cant remember the way it is on our cars, it will either read full or empty when the two wires are touching for the gauge. It will do the oposite if they are open but Im thinking yours has an open somewhere in the wiring or it may be a bad sending unit.
Old Oct 5, 2002 | 09:38 PM
Andy Bush's Avatar
You can measure the resistance in the sender and the wire going forward, by disconnecting the wires at the connector which is near the tank. It is the one you have to undo to get the tank out. You can see is there is a short going forward to the gauge, or open circuit or short circuit at the sender end.
You put the ohm meter contacts into the wires after you disconnect them. The wires supplying the power to the fuel pump are grouped with the sensor one.
Ghettobird52
Jul 5, 2024 11:18 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
