Help, fuel pump stays on
Old Dec 10, 2001 | 12:01 PM
surg187's Avatar
I've recently started having a problem with my 89 Firebird. Sometimes when I turn off the car and remove the key, the fuel pump continues to run. It varies how long it continues to run for, but usually around 30 seconds. One time it stayed on until I disconnected the batttery. I already changed the fuel pump relay, but I doubt that is the problem because if you disconnect the relay the fuel pump continues running. I hear the fuel pump click when the fuel pump turns off so can someone explain how the fuel system works, i.e. where does the fuel pump relay get the signal. Any ideas on what can be the problem or any info is appreciated. Thanks.
Old Dec 10, 2001 | 02:09 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is an oil pressure operated switch screwed into the block, located just above the oil filter, that is paralleled with the fuel pump relay. Sounds like that is the problem. To verify that it is, remove the plug from the switch.
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
