My tail lights are not working.......
Old Dec 5, 2001 | 07:51 PM
Tobe2wild's Avatar
Heres the deal my taillights do not work when I have my lights on. My brake lights work when I hit the brakes though? My gauge cluster lights also are not working. Any ideas? Derek
Old Dec 6, 2001 | 01:04 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'll guess it's a camaro ?
By some freak chance they could both be burnt out at the same time. The bulbs are dual element. If the front marker lights are comming on than the backs should to as they are all tied together from the light switch (in a way). The other chance is the wiring running to the back is broken somewhere. i'd start with bulbs, while you have them out, test the socket for power if you have handy or can get a voltmeter.
Your cluster problem could simply be a popped fuse. Under the dash in the fuse panel there should be a 5A fuse labled INST FUSE yank it & give it a look-see.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"I don't know the key to success, but the key to failure is to try to please everyone."
Old Dec 10, 2001 | 02:54 PM
82camaro's Avatar
Car: 82 camaro SC
Try the fuse first. The same fuse runs the tail lights and dash lights. Brake lights are on a separate circuit.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
