headlight prob
Old Dec 14, 2001 | 12:10 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
headlight prob
well i went to turn on my brights last night and they aint workin. i just installed 2 new halogens for low beam and they are bright as hell but i still would like everything ot work on my car. any suggestions. the connections are all there i 2x checked. so when i pull the switch the lows go out and one bright comes on. thanx in advance guys!
-PETE
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Old Dec 18, 2001 | 11:02 AM
mtccl's Avatar
Sounds like your relay went out. I'd check that first.
Old Dec 22, 2001 | 01:49 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It could be a minor problem,...... like crud build up between the button and the contact point on the circuit board - Or it could be a bit more of a problem, like a bad light module.
I'm really not sure the best way to test the car in order to see which is faulty......... If I find some info I'll post it in here for ya'.
I can't see why installing new lamps would cause a bug in the system ------
John in RI
Webmaster@Berlinetta.info
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
