Anyone have a ESCM fora 87-92 TPI camaro for sale?
Old Dec 13, 2001 | 05:53 AM
SS-IROC-Z's Avatar
i am looking for a ESCM?
Old Dec 14, 2001 | 01:25 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I know what an ECm is but not an ESCM. You may try searching the classified on this site
https://www.thirdgen.org/classifieds
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"I don't know the key to success, but the key to failure is to try to please everyone."
Old Dec 14, 2001 | 02:30 PM
SS-IROC-Z's Avatar
Its called Electronic Spark Control Module its located some where on the passager firewall i am not sure.I am doing a TPI swap and i was told i would need a 350 ESCM.I am not sure what it is either.
Old Dec 20, 2001 | 11:01 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I'm pretty sure the guy meant to say ECM. Electronic Control Module. I see them on eBay all the time. The part numbers differ for the different TPI systems. I am not sure what the number is for the MAF TPI (??-1989), but the ECM part number you want for a Speed Density System (1990-92) is 1227730. I have read that the ECM in the V6's is the same as the ones from the V8 Speed Density TPI's, so you might try a junkyard in your area to find one. The only problem with a V6 ECM is that you will have to either get a 350 TPI chip, or burn one yourself, which is probably your best bet. See the DIY-EFI board for more info on burning chips.
Old Dec 20, 2001 | 12:41 PM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
No.... he ment ESCM. Its a little yellow box behind the dash board (has AC printed all over it), and its calle the Electro Spark Contol Module. It basically reads the detonator sensor, and puts out-put to the ECM. the wires going into it are pink/black, and coming out of it are wht(to the detonation sensor), brn (to ground) and black (to ecm). I have one for a 305 that i'm planning on swapping into a car, and don't have one to spare, but i wanted to clear up the matter that he's not looking for an ECM (Electronic Control Module).
Just a bit of intersting info.
Joker
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
