Do I Need The Computer?
Old Oct 15, 2002 | 03:55 PM
flippinTHEbird's Avatar
I have an 88' Firebird. I pulled the 305 TBI for a 76' 400 Carbed. (Still to be installed) Will I need the computer for anything?
Old Oct 15, 2002 | 04:02 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
post this in the DIY PROM board, someone will know there.
Old Oct 15, 2002 | 07:15 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
No, however, if you plan to use the in tank fuel pump to supply fuel to the carb, you will need to wire the fuel pump relay coil to the cold start injector power wire coming from the ignition switch to power it during cranking. You will need to use the fuel pump oil pressure switch to power the relay while the engine is running, as well. You will also need to use a different (non computer controlled) distributor.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
