did search: remote start and VATS????
Old Oct 21, 2002 | 11:19 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I'd like to get a remote start and keyless entery, I've searched and came up with two different answers, so can i get a system for my 91 and keep VATS? and if so where should I get the system? brand? so on?
Thank you
Vic
Old Oct 22, 2002 | 12:00 AM
Boxeat2469's Avatar
Any system you'd like will work. The key to it is just a relay and a resistor. When the key is used, the VATS signal goes through the key as usual. When the remote start is used, the relay reroutes the VATS signal through the resistor. The resistor must be the same value as the "chip" in your ignition key. The Bulldog Security setup that I used had in its instructions how to do it. I wouldn't recommend that brand though. The range sucked on mine, and out of three systems that I bought about a year ago, only one is still working. The other two both shorted out.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
djmarch
Aug 19, 2015 12:07 PM
