there is something wrong with my headlight motor
when i trun on the headlights on my 86 t/a my right side headlight works fine but the left side dont, if i crank the headlight up by hand (lots of cranking) then when i go to shut off the lights it goes down fine, i was told that my motor isn't burned up because it wouldn't go down if that was the case, i already tryed one rely by switching it from side to side and it made no difference. i'm stumped, i thought it was and iteresting fact that the headlight that dont work is lose and moves alot when i wiggle it but the head light that works is tight will that make a difference, please help
Dogg,
There are end-of-travel limit switches in the headlight assemblies. If you diable the headlight motors and push-pull up and down on the hand operating ****, you should be able to hear the switches clicking. Chances are, the switch for the upper limit on your left side motor is not closing after the headlight is lowered.
This might help you see the scheme:
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
