AC/Heat Fan
Old Oct 28, 2002 | 07:22 PM
MasterEvilAce's Avatar
AC/Heat Fan
Alright, just wondering if anyone had ANY idea about this
The fan works on low, medium, but not on high. the blower shuts off once you turn it on HIGH. Think the component itself is screwed? Or maybe a wire, or something else that could cause it to shutoff on high?
Old Oct 29, 2002 | 09:45 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There is a 'blower high speed relay' located on the HVAC box or somewhere really close. The relay is dirctly powered by a heavy gauge puprle or red (or maybe red in purple out, purple in/out... some combo those colors ..I forget.. anyways..) that goes directly to the starter (main lug) and has a fusible link on it. At least one of those heavy wires should have +12v on it at all times (both if the fan is on high. If there's no power at that relay, the fusible link may have broken or shorted.
Old Oct 30, 2002 | 11:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had a similiar problem on my 85 IROC. As I recall, the resistor wire had simply burned through. A five minute job to replace.
JamesC
Old Oct 30, 2002 | 08:03 PM
MdFormula350's Avatar
here is a wiring diagram
Attached Thumbnails AC/Heat Fan-heating.jpg
Old Oct 31, 2002 | 06:18 AM
thanks a LOT!
will work on it today
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
