Will an 85TA and 88 Firebird Harness work?
Old Oct 29, 2002 | 12:40 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
ok heres the deal. i have an 88 firebird. the dash and all that other wiring under the dash is all screwed up. i got my friends harness, dash steering column out of a 85TA. Will the 85 harness work with my 88 harness under the hood? j/w if i can goahead and install thedash without any problems.
Old Oct 29, 2002 | 09:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I can't say for sure but, 2 things that would be different come to mind and that is, 85 having a mechanical speedo & 85 & 89 headlights have different setups as far as the way the lights are controlled for rasing & lowereing. I'm sure that the harnesses could be modified to use but, as a guess, I'd say they won't directly swap.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
jharrison5
Aug 19, 2015 05:53 PM
