Can the vats system still malfunction even if the computer does not give a code.
Old Oct 30, 2002 | 09:45 PM
JDV's Avatar
JDV
My car sometimes does not want to start or do nothing. I'm pretty sure it is the vats system. Like today it did not start so I checked the computer for codes it give me a code 32 for the EGR. Is it posiable that the vats can still be messed up,and the computer not give me a code.
Old Oct 31, 2002 | 06:22 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: Can the vats system still malfunction even if the computer does not give a code.
Not very likely if the module itself or the key contact is not working. If the starter relay is acting up it will not normally throw a code. Vats models use a starter enable relay usually located behind the driver kick panel.
Old Nov 5, 2002 | 10:59 PM
otterball21's Avatar
key?
how worn is the key? check the key out if it's worn that little chip is not contacting properly.... get another one made
9192camaro
16
Feb 3, 2019 12:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
zayne0
Aug 24, 2015 07:22 PM
