tac is off, please help
Old Nov 10, 2002 | 05:18 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
ok, on winaldl the rmp is 500 at idle and my tac said 750, winaldl 1900... tac 2600, winaldl 4000... tac 6100, at least from the best of what I can remember from yesterdays tuning, anyways, how can I fix this?
Old Nov 11, 2002 | 12:27 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
ok does your car have a stock motor? is it the original tach?
Old Nov 11, 2002 | 06:40 PM
rsc350's Avatar
Car: 92 Camaro RS
not stock motor, stock tach though, see sig...
Old Nov 11, 2002 | 11:55 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
ok then the answer is simple....you swapped from a 6 to an eight, you have 2 more cylinders than your stock tach is programmed for, so it will always read 33% higher. Get a tach out of an 8 and replace the one in your dash, easy fix.
Old Nov 12, 2002 | 10:03 AM
Morley's Avatar
Actually, using a V 6 tach on a V8 car will result in lower tach readings, not higher. Since the tach signal is a single pulse ( say for argument sake #1 cylinder firing) with an 8 cylinder engine that pulse will happen less often than a 6.
Old Nov 12, 2002 | 10:19 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Much as I hate to disagree with you, I think I am right. Had the problem first hand. I think the solid state circuit board actually "counts" the number of ignition pulses sent from the HEI distributor i.e.: one pulse=one cylinder fires, and is programmed for 6 or 8 pulses per turn. I've seen tach circuit boards that were marked V6 or V8. Whichever one of us is right, I bet if he gets a tach out of a V8 car or even just the board off the back (what I did), it will read a lot closer...g*d knows that the stock tachs are about as accurate as Enron's accountants.
Old Nov 12, 2002 | 05:41 PM
rsc350's Avatar
Car: 92 Camaro RS
Would it be possible to put a resistor in line to the tach? I dont want to change the tach again , besides I tried the tach out of a V8 when I got the new 145mph speedo, It read the same, but I liked the looks of my original better, a little bit beter condition, so I put the original back in.
Old Nov 12, 2002 | 11:53 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
you are supposed to be able to fix it by placing a new capacitor on the board, but I never had any luck with it. Do a search on tach fix on this board, there are several threads discussing ways to actually fix it. It is a very common problem for the stock tach to fail and read wrong.
Old Nov 13, 2002 | 02:28 AM
Morley's Avatar
I got a tach off E bay to replace my failing tach and installed it without looking to be sure it was for a V8, Well, the rpm's read way low for any given speed of the vehicle. I pulled the tach and flipped it over, low and behold, there was a little sticker that read 6 Cyl.
The guy swore the tcah was from an IROC....don't remember any of them having 6 bangers in them.
Then, I replaced the large capacitor (on the v6 tach) with one of another value ( forget what exact value) and it read correctly.
Old Nov 13, 2002 | 07:03 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
thats wierd, because both of the 6 cyl tachs that wound up in my IROC read high, always about 1/3 higher....I did try to do the fix like you did, but it didnt work right...so what I have now is a circuit board from a V8 tach mated to the guage head and face of a V6 tach that matches the rest of my guages, works great its as accurate as a stock tach is gonna get
to rsc350: I say try morley's fix, I know other people have had good luck with it. Do a search on tach fix, that should find the thread. If it doesnt work you'll be out some time, about a $1 in material and probably a lot of cussing and if it doesnt work you can do what I did.
Old Nov 13, 2002 | 04:49 PM
rsc350's Avatar
Car: 92 Camaro RS
Hay thanks for ths info guys, i apreciate it. I'll give it a whorel.
Old Nov 13, 2002 | 05:25 PM
rsc350's Avatar
Car: 92 Camaro RS
I looked all over the place and I cant find anything on a tach fix, nothing except replaceing it, I know there has to be a way, you guys know too, any directions you can tell me, or maybe you guys can find a link to a fix??
Old Nov 14, 2002 | 02:12 AM
Morley's Avatar
Check this thread.
https://www.thirdgen.org/techbb2/sho...hreadid=109181
It describes how to make a V6 tach work on a V8 engine.
I gave a pretty good description of where the capacitor is on the tach on this thread. https://www.thirdgen.org/techbb2/sho...hreadid=114057
Look at my second post on that thread, the first one I was a little off in the position of the capacitor.
92firebirdguy
Sep 1, 2016 07:53 AM
Irocohio
Aug 12, 2015 08:03 AM
worldofool
Jul 18, 2002 01:41 AM
DISTURBthePEACE
Jun 3, 2002 06:33 PM
