fried temp sender wire
Old Nov 13, 2002 | 06:07 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I fried the green temp sensor wire on my headers while it was hooked up .Pulled the melted wire off the headers it didnt look broken so I taped it up and the guage stays at 100. I will check the wire with a meter tomorrow to see if its broken.Could I have killed the sensor or guage?
Old Nov 30, 2002 | 01:39 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I would be very surprised if you have hurt anything. More likely that the spliced connection isn't good enough.
Even more likely that you've already fixed it by now!
You might be able to find some fibreglass sleeving to put over the wire before you permanently splice it (solder it up?).
Old Dec 1, 2002 | 12:24 PM
MdFormula350's Avatar
might need to solder in a new wire, where the existing wire was burnt.
Old Dec 2, 2002 | 05:23 AM
e-man's Avatar
Car: 89 formula
Engine: 383
The guage did get fried.The wire was ok just had to tape it up where the insulation melted.
Old Dec 2, 2002 | 11:35 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
So the gauge suffered from that huh? Well I learned something today. I never would have thought that grounding the temp sender lead would damage anything.
What did you do, just replace the temp gauge by itself from a wrecker?
Old Dec 2, 2002 | 04:01 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Not yet still driving around with no guage
BRoss99
Aug 10, 2025 05:08 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
355sbcTPI
Aug 19, 2015 04:38 PM
penguinpanda0
Aug 15, 2015 06:45 PM
