What does it take to switch to 145mph speedo?
Old Nov 17, 2002 | 02:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have a 90 Rs with the 110 mph speedo and would like to convert to the 90-92 145 mph speedo. How would I callibrate the new speedo. I am pretty sure all of the other gauges are the same and will work without adjustment.
Old Nov 17, 2002 | 03:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Take the old one out and put the new one in. It's that easy.
Old Nov 17, 2002 | 04:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
So it is a direct plug in? There isn't any conversion needed?
Old Nov 17, 2002 | 08:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Nope. The speedometers expect the same number of turns of the speedometer cable per mile or same of pulses from the VSS per mile, regardless of how high the scale goes.
Old Nov 18, 2002 | 12:00 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
wHAT ABOUT THE SWITCH IN A '86 FROM THE 85 TO 145 SPEEDO? ANY ADJUSTMENTS OR JUST SWAP 'EM IN.
Old Nov 18, 2002 | 08:58 PM
AFast83z28's Avatar
speedo switch
what about since I am using a powerglide now instead of a 700r4? do in eed a new calbe?
Old Nov 19, 2002 | 08:42 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
stock speedo's are a direct plug in mechanical to mechanical or electronic to electronic, it gets tricky when you go from one to the other.
If your current speedo is working fine with the powerglide, then no you dont need to change cables...if it isnt working right, there could be several reasons.
GTAman
Jul 3, 2024 07:29 PM
tglennon11
Sep 23, 2015 05:30 PM
TrevinE
Sep 14, 2015 03:20 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
