wiring harness questions
Old Nov 19, 2002 | 08:22 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
When taking out a wiring harness from a '86 TA, does anything need to be disconnected from the tranny or from the gauges? Is the a/c and fans on the harness? What is involved in takinf out the harness? What is the easiest way to remove and install a engine harness?
Old Nov 20, 2002 | 10:27 AM
Jza's Avatar
Jza
There's one branch to a 4-prong connector on auto trannies. There shouldn't be anything on the engine harness related to the gauges except the oil pressure gauge IIRC. Later cars combined the harnesses and you got a lot more, but on an 86 you shouldn't have all that.
A/C, no, fans, yes, though sometimes it's a sort of "sub" harness that can disconnect at a 5(?) pin connector and is often missing when you raid boneyard cars.
A lot of unplugging mostly.
With the motor out of the car on an engine stand. Obviously if you're just swapping a harness that's not practical, but you did ask the easiest way.
Old Nov 20, 2002 | 06:41 PM
Matto'85TA's Avatar
IIRC?
What is IIRC?
Thanks for the help.
Matt
Old Nov 21, 2002 | 11:27 AM
Jza's Avatar
Jza
IIRC = If I Remember Correctly
Old Nov 21, 2002 | 05:43 PM
Matto'85TA's Avatar
I was just told the '86 wiring harness won't work with my '85 dash harness and guages. Is this correct? They said the connectors may fit but the gauges in my '85 are mechanical and the '86 are electronic. I have access to the '86 as a parts car, should I pull the gauges and dash harness? What is involved in pulling the dash harness and gauges? Will anything else not work?
Matt
Old Nov 22, 2002 | 08:58 AM
Jza's Avatar
Jza
Only the speedometer is a concern, the rest of the gauges will work.
Think about it.. a mechanical gauge wouldn't have an electrical connector, would it?
And since your speedometer is mechanical, you'd be able to keep the cable in the car and retain your speedometer function. You shouldn't have to move any wires to get a VSS signal to the ECM either, but that's not in stone. There's so many differences in the last 5 years and between the two makes it's hard to say.
Old Nov 23, 2002 | 07:12 PM
Matto'85TA's Avatar
Everything should work fine then? What does the vss signal do for the ecm? I want to make sure everything will hook up with out a problem and work properly. No mods to the harness is needed is there? I was told it wouldn't work by the guys at TA Creations.
Matt
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
