accel 300+ installed/ 15volts showing
Old Nov 22, 2002 | 12:31 PM
k9camaro's Avatar
Just installed accel 300+ ignition and my voltmeter is showing 14 and 15 volts, while running. I've read about several ignitions but I've never heard of this happening, maybe it's ok, just want to check.
Thanks for the help..
Old Nov 30, 2002 | 01:33 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
You're talking about the factory voltmeter on your instrument cluster are you?
Is it reading higher or lower than it used to before the ignition box? Your numbers sound perfect to me.
Old Dec 1, 2002 | 12:22 PM
MdFormula350's Avatar
sounds ok to me, when i am driving the volt meter in the car reads alittle over 13 i believe..
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3.8TransAM
Oct 1, 2015 07:47 PM
efiguy
Sep 27, 2015 01:30 PM
