O2 sensor wire melted......what should i do?
Old Nov 23, 2002 | 11:12 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i talked to my brother and he said that i need to do it in a way that would create as little resistence possible cuz of the extremely low current through the wire........well if i soldered a new wire in wouldn't that be good enough?
as or right now the connector is melted to the exhaust and my car is running rich becuz of the bad readings.....
Old Nov 23, 2002 | 03:05 PM
dsaint1347's Avatar
Remove the melted cable and solder on the new cable with the connector, your car will run like crap without it
Old Nov 25, 2002 | 01:58 AM
kingrobert's Avatar
resolder your cable, then get an o2 simulator and mount it away from the exhaust:sillylol:
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Bert87
Aug 23, 2015 03:50 PM
