Air intake sensor
Old Nov 26, 2002 | 10:40 PM
AmorgetRS's Avatar
Air intake sensor
I was wondering what type of gauge/sensor should be used to measure the temperature of the incoming air in a Forced Induction system?
Would a ambient air temp one that works up to 225 degrees work?
Thanks,
Douglas
Old Nov 30, 2002 | 01:28 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I was just digging around for my supercharging book to look into that but I can't find it, you have me curious now.
You're talking about monitoring the air temp of the compressed charge going into the engine, right?
I suppose if you are in a warm climate and the supercharger is ingesting air at about 100 F ambient it could be a whole bunch hotter from the compressing and shearing action of the blower, but how much hotter I don't know.
If you were running tons of boost I suppose you could be getting up to/past 225 F, but at 10 lbs I don't know. The 'Street Supercharging' book has some graphs depicting typical charge temperature increase vs. boost for roots-type blowers.
Old Nov 30, 2002 | 02:31 PM
AmorgetRS's Avatar
Actually, it is a turbo application (even hotter) running though a IC. I'd just like to know what my air intake temp is, mostly curiousity. But yes, that is exactly what I was asking for... but unless I go with a rather expensive exhaust gas temperature one I can't seen to get over 225 degress, and I don't really need to go up to 1000 dgerees or whatever w the EGT...
Old Nov 30, 2002 | 02:46 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
I guess an auto transmission temperature gauge would read between 225 and 1000 F but likely very slow to react to temp changes getting on and off the boost.
There probably is an industrial remote-sensing pyrometer for the job but likely really pricey.
Old Nov 30, 2002 | 03:25 PM
AmorgetRS's Avatar
Yeah, I guess I will go w/ a 0 - 1000 or something EGT. Too bad they are like 100 bucks, but I guess that isn't bad.
Old Dec 5, 2002 | 08:12 AM
Vader's Avatar
A coolant temperature gauge that uses a factory type sensor would be about the right range for IAT sensing, and the sensors are readily available.
Old Dec 5, 2002 | 01:04 PM
AmorgetRS's Avatar
Sweet! That is the answer I was looking for! Thanks!!
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
