86 IROC 3rd Brake Light
Old Nov 28, 2002 | 03:36 PM
restoIROC's Avatar
Car: 2000 Monte Carlo SS
Engine: 3.8 V-6
Hey guys-
My third brake light stopped working awhile ago, what could be the problem...??? Is there a fuse or something that is burnt out?
Thanks,
Ben
Old Nov 28, 2002 | 09:20 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I've been havin problems with mine, and I determined that it is the connection between the hatch and the body. The little spring connections on the hatch side break the connection over time. Mine is somewhat intermitant. From what I figure, these connections should not wiggle around much. This should get you in the right area.
Old Nov 28, 2002 | 09:25 PM
restoIROC's Avatar
Engine: 3.8 V-6
Thanks....I will try that tomorrow, it sounds like something that could be happening. My hatch contacts are not the best so I will try that-
LAter-
Old Dec 3, 2002 | 09:34 PM
restoIROC's Avatar
Engine: 3.8 V-6
All better
Fast Electrics-
I checked over everything and something was fishy. There were plugs on the sides of the back window that had no plugs going into either one of the two. I just made a wire with two connectors and WA-LA, athe third brake light that hasn't worked since I bought the car 3 years ago suddenly started working
Thanks for the input-
Frozer!!!
Jan 19, 2024 04:55 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
stalkier
Aug 13, 2015 12:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
