RH T/A headlight dim?
Old Nov 29, 2002 | 03:00 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
For some reason, my RH headlight on my '84 T/A got real dim all of a sudden. Not out, but dim. Also you can vaguely see the brights indicator on, and it comes on for a second when you first turn on the lights. Bulb's OK, so are the fuses and headlight motors. Anybody have any experience with this?
Old Nov 29, 2002 | 07:06 PM
1986redbird's Avatar
check the ground wire going to that light, they usually break right where the connector is plugged into the bulb. despite assumptions to the different the light will still burn without the ground wire, just very dimmly.
SRKLEGIN
Oct 29, 2015 06:38 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
