headlights always on
Old Dec 7, 2002 | 04:31 PM
mrbboy's Avatar
My high beam lights are always on. Flipping the switch on the steering column doesn't do anything. Anyone know what my problem could be? Is it the high beam switch on the column or a just a relay? Where is the headlight relay located? How hard is it to replace the high beam switch. I would really appreciate any help.
Rene
Old Dec 7, 2002 | 04:41 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
More details would help...type of car, year of car, model of car. Can't answer your question without the details
Old Dec 7, 2002 | 06:24 PM
mrbboy's Avatar
Sorry, I forgot that information. My car is a 91 Camaro RS.
Old Dec 8, 2002 | 09:14 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I would have to say I don't think it is a relay...It is most likely the switch itself, which will require you to remove the steering wheel and all the goodies inside the column to replace it. For this you will need a steering wheel puller and a tool to compress the plate so you can remove the switch. This can be a bit of a pain, so I would advise you to take it to your mechanic to have it repaired unless you have these tools and are very good, when it comes to repairing cars.
HTH
Keiran
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
