Screwy Tack!!!!
Old Dec 8, 2002 | 09:27 AM
Elric's86-Z's Avatar
Screwy Tack!!!!
Ever since the motor was swaped into my 86 IROC Z the tac stays at about 4-5000 rpm.
When you drive it pegs out,did someone hook up the wires wrong?? somewhere in the eng compartment???
Old Dec 8, 2002 | 03:31 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Depending on the old and new engines, you could have a counting problem, or voltage problem. If the old engine was a four or six cylender engine, and the new one is an eight cyl., you will need either a chip or a reducer added on to your old tach or computer. If the old engine had fewer cyls., the computer is still counting that number, so every time 6 or 4 cyls. fire, it counts 1 rev as opposed to 1 every eight. Another problem might be the voltage. If the engine you swapped in was the same number of cyls. as the old one, the distributor might be putting out a stronger signal. Try inserting a reducer in-line to the tach to rectify this.
Hope this helps,
-Berlinetta00
Amillionoh7
Sep 5, 2015 11:44 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 7, 2015 09:41 PM
BLUEIROC5.7
Feb 28, 2002 11:41 PM
Christos
Jun 15, 2001 12:25 PM
