Bouncing tach, bad cap or module?
Old Dec 15, 2002 | 08:25 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
A couple months ago my Auto gauge (ow end Auto Meter) tach started from a steady RPM to periodicaly bounce from the cruise RPM to redline and beyond and back. Eventually the tach quit working all together (fluttered constantly) and I swapped it out for a new Auto Gauge with a shift light in the dial. Hooked it up, it worked fine. Then I went for a long drive, sure enough once the engine was hot the new one started to do the same thing, not too frequently but it did it. I disconnected it to save it.
I have been told it's one of two things.
Cap arcing inside. I have looked, no sign of this, no carbon track. I have looked at night and seen no shorting plug wires either.
Bad module. THe engine runs perfectly, no miss or anything.
It is a stock HEI with a vaccum advance can, non computer controled.
Any suggestions?
Eric
Old Dec 17, 2002 | 06:47 AM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
replace your ICM....ignition control module...my 1992 Firebird did the same thing also with the stock tach in it, i tried doing the cap thing at first also but nothing once i replaced the module it has worked fine ever since.........
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
stalkier
Aug 7, 2015 04:49 AM
