Need instrument cluster pinout diagrams for 85 ta and 86 t/a
Old Dec 29, 2002 | 03:11 AM
Momar's Avatar
I followed the instructions in the tech article to convert to an electric speedo cluster and well let me tell you things didnt work out as planned. I have the cluster here and looking at the routing on the back of it I can tell why. Let me explain the problems I am having. The brights light is on all the time, the left turn signal flashes the right arrow, the right turn signal doesnt flash any arrow, but pulses my fuel gauge, the tach doesnt work, and the speedo acts as if it is a tach.
It appears that the wire that now goes to the brights light was origionally went to the green wire on the speedo mounted vss. The right turn signal wire appears to go to one of the fuel gauge spots. What was origionally the left turn signal now appears to be the right. The wire that origionally went to the brights is now running to one of the tach wires. A spot that origionally did nothing but has a hole for a light that may have been used in another application is now going to the other tach wire.
Well, I am not sure that all of that is exactly correct but my mind is starting to go numb from tracing it all. Anyway, I just basically need the diagrams if anyone has them.
Ben
Old Dec 29, 2002 | 08:02 PM
Momar's Avatar
ttt
InfernalVortex
Apr 20, 2021 11:31 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
