Wiring harness question
Old Dec 30, 2002 | 12:06 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I am in the middle of an engine swap and am trying to get the wiring harness out of the engine bay (I am also going to paint the engine bay- so need to get it out of the way).
I see that the main wire bundle goes from the passengers side to the drivers side firewall.
My question is: Does the wring harness unplug from the firewall on the drivers side?
I see a connector there and unclipped it, but the wire bundle does not move.
Any info appreciated-
S-D
Also- if this should be posted elsewhere- please advise
Old Dec 30, 2002 | 12:40 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There is a 6-9mm bolt (I forget which size exactly) in between the 2 harness plugs that needs to be backed out before they will disconnect from the bulkhead connector.
Old Dec 30, 2002 | 01:02 PM
Car: 1991 RS
Thanks for the reply-
I will try that- now that you mention it, I recall seeing an approx 8mm nut on the firewall there.
S-D
Old Dec 30, 2002 | 01:40 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Actually I think it is a 5mm or a 8mm, if I remember right??
Old Jan 5, 2003 | 10:26 AM
mschwitz78's Avatar
wire harness removal
You say you are doing an engine swap, right? What are you switching to, and if it's not another 305, are you looking to sell your 305 tbi wireharness?
Old Jan 6, 2003 | 07:00 AM
Car: 1991 RS
Am switching to a 350 tbi. No, not interested in in yanking my wire harness to sell. Was looking to get some of it out of the engine bay to make cleaning and painting the engine bay easier.
S-D
Old Jan 6, 2003 | 08:59 AM
mschwitz78's Avatar
That's okay, I already found one. Thanks anyways.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
