Starting Problems
Old Dec 31, 2002 | 03:42 PM
AFast83z28's Avatar
Starting Problems
Sometimes my car will crank and sometimes it will not. When it doesn't crank, I still have all my accessories but no turn over. I can't hear the starter turning over. So far I have had these reccommendations on what is wrong :
1) Ignition Switch
2) Ground Safety Switch
3) Flywheel missing a few teeth (can't hear starter turning tho)
4) Shifter cable (sometimes it thinks it is in gear when it is in park)
ANY help as fast as you can would be a great help. Also there is a new starter on it.
Old Dec 31, 2002 | 03:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
This may/may not help you diagnose your problem...
https://www.thirdgen.org/techbb2/sho...hreadid=151710
Old Dec 31, 2002 | 03:58 PM
AFast83z28's Avatar
Post
Thanks I read that just before I had posted. Just was wondering if anyone else could help out. Where is the ground safety switch? and is there a park/netural switch or something likethat?
Old Dec 31, 2002 | 07:34 PM
Morley's Avatar
Re: Post
That sounds like a made up name or possibly someone's understanding of the park/neutral switch. That switch is located on the shifter bracketry. That would be a good place to start troubleshootng, make sure it is securely mounted in place.
Old Dec 31, 2002 | 07:44 PM
AFast83z28's Avatar
Park/Neutral Switch
He said the Ground Safety "something" i dont remembmer if it was switch or sensor or what. He said it was located on the column though. Maybe he didn't know I will definitely look at that park/safety switch. Is it the BLACK plastic thing with wires coming out? If so that is probably the problem, because it is not mounted.
Old Dec 31, 2002 | 08:53 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: Park/Neutral Switch
That could be a problem If there is a heavy gauge purple and a heavy gauge yellow wire among the others, that is it (park.neutral switch). If that's not mounted that would also mean you don't have any working reverse lights
Old Dec 31, 2002 | 09:24 PM
AFast83z28's Avatar
Re: Re: Park/Neutral Switch
uh that can't be healthy
Old Jan 1, 2003 | 03:42 PM
AFast83z28's Avatar
aahhhhhhhhhh
This still isn't cranking. It is not turning over at all now. Need help quick before dark!
Old Jan 2, 2003 | 11:39 PM
racerx004's Avatar
You said there is a new starter in it. How long ago was it installed? Check to make sure nothing came loose from the solenoid on the starter.
Old Jan 3, 2003 | 01:15 AM
AFast83z28's Avatar
starter
The starter was installed for christmas maybe two weeks ago. I think it was the thing I left unhooked. It has been cranking since I hooked it up so we are going to hope this was the problem! :lala:
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
