wiring 4cyl car for 350
Old Jan 5, 2003 | 04:51 PM
makeitrock's Avatar
I picked up a 83 4cyl. camaro cheap, pulled the four-banger and auto tranny out, now I need to know how to wire the darn thing for my 350, doing away with computer, have plenty of automotive experience on older stuff but never done this,any suggestions out there?
Old Jan 11, 2003 | 06:41 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I don't think you have too much work ahead of you really.
I have been in a similar situation, pulling a MPI 2.8 V6 out and dropping in a carbed V8. You only really need to keep the heavy red wire for the HEI (probably exactly the same), any guage wires that went to senders on the old 4 cyl, the starter & alternator wires... That's about all that I can remember. Keep the tach lead if you have one.
The rest of the wiring going to the computer is in it's own harness to some extent, so it will be somewhat separate.
If you find the wiring that you definitely need to have, like the ones I mentioned, and any more that you or other members may think of - the rest you can remove but I would wait until the car is running!
Old Jan 18, 2003 | 08:31 AM
Cam84358's Avatar
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
I agree it looks worse than it really is.Get a service manual I used Haines and I bought a factory manual also.I also did the v6 to v8 swap.take a look at your present wiring.See what you need to eliminate.I ditched the computer harness,sensor wiring,etc.I kept the wires for the starter,and the distributor wire [ 12 volt source with key on].I kept the alternator wiring but I am using a one wire altnernator.Im using mechanical guages for temp,oil,bat.and a after market tach.This was for a 84 Camaro running a carb.
midge54
Sep 2, 2020 07:13 PM
theshackle
Mar 5, 2017 06:37 PM
penguinpanda0
Aug 15, 2015 06:45 PM
milk
Aug 10, 2015 06:26 PM
