Map light and flashlight
Old Jan 6, 2003 | 01:41 PM
REDRIDER89125's Avatar
Does anybody know what size lightbulb the little map light in the overhead console is. Same with little flashlight, what size bulb is that. Where can I get these?
Old Jan 6, 2003 | 03:05 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
The map light is a #194 bulb, you can find these at your local auto parts store. The flashlight uses a 2.3-2.6 V threaded bulp, I forget what the PN is. You can get these at a radio shack, or other electrical supply store (possably a hardware store?). Bring the flashlight in with you to get the correct size.
Here's a tip: You can get colored #194 bulbs, using red, amber or blue to obtain a suprising color, and avoid window glare at night when you have to read directions or change CDs.
Old Jan 8, 2003 | 09:04 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Good advice. I was about to ask the same question and then I found this thread. Searches are great.
fasteddi
Sep 10, 2015 09:32 AM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
andy74
Sep 3, 2015 08:41 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
Omega
Aug 10, 2015 12:46 PM
