irratic idle
Old Jan 7, 2003 | 12:01 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
irratic idle
I own a 88 trans am 305 TBI and Every so often when i started the car it would run really low on the rpm. so i decide to reset the timing. I read you have to unplug the est wire. so i thought i was doing thatbut i was unpluging a different wire. Its a single wire right above the heter core mini radiator right on the fire wall passenger side. My question is when i do the timing again so I unplug that as well as the est wire( i just figured out where it is yesterday) or just unplug the est wire.
Let me know you f-body experts out there!!
Old Jan 15, 2003 | 12:25 AM
evelkneivel001's Avatar
Car: 87 GTA
Engine: 383 Stroker
Transmission: 700 R4
just est or both?
I have an 87 and I've set the timing quite a few times. Only unplug the EST wire when setting time. Make sure car is warm. After setting time, tighten down distributor and re-check before plugging EST back together.Not too hard!
Old Jan 15, 2003 | 01:24 PM
TransAmTBI's Avatar
Engine: 305 TBI
ok i also think i have a bad connection cause i get code 42 and i cants see any phisical problem unless i have a bad dist modual
but thanx for the advise
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
