Electronic Exhuast cut out....need help with wiring
Old Jan 12, 2003 | 12:53 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey There, I have an electronic exhaust cutout I got for christmas...I stalled the switch and the led light. Grounded it and connect the postive wire into my fuse box. They said to choose a power source that is used when the key is turned to the "on" position...so...I put the postive wire into the injector fuse (1991 Z28 5.7 L98 TPI).....I've had on hooked up for 2 days...I went out to start my car...and my battery is completely dead...?? The fuse that I hooked the postive wire into should have worked...cause it only woked when the ignition was turned to the "on" position which controls the injectors. So......what other fuse could I hook this into so it won't discharge my battery??? Any help would be greatly appreciatied. Thanks
Attached Thumbnails Electronic Exhuast cut out....need help with wiring-1991z282.jpg
Old Jan 12, 2003 | 01:49 PM
MdFormula350's Avatar
maybe try the a fuse thats used for interior stuff thats has 12 volts when the key is in the on position..
Old Jan 18, 2003 | 04:40 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Not sure about your car but on mine there is an ACC plug on the fuse block...
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Aug 15, 2015 10:47 AM
apie2546
Aug 8, 2015 07:12 AM
