foglight wiring
Old Jan 15, 2003 | 12:43 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
foglight wiring
Just put in foglights. Any way to rig them so they can go on without the parking lights on? I want to use the factory switch. Also, how do I keep them on with the brights on?
Old Jan 15, 2003 | 02:34 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you want them to be controlled independantly of the parking lamps, just wire the switch directly to a relay.
Send +12 ignition to one side of the switch, then the other side of the switch to pin 86 on the relay.
Ground pin 85 on the relay.
Send fused battery voltage to pin 30 on the relay, and hook the fog light wires to pin 87 on the relay. Ground the fogs to chassis.
If you want the fogs to operate only with park lamps and low beams (like the stock 86+ cars were), you can follow this tech article that I wrote:
http://iroc.fbody.com/fogs/relay.html
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
