scan tool for CC Q-jet?
Old Jan 16, 2003 | 11:44 AM
Sparkee's Avatar
I'm trying to get some info reagrding the CC Q-jet ECM's. I'm building a circuit that plugs into the ALDL so I can use a laptop to communicate with the ECM. I really need to find software to work with this older ECM (part# 1228079) on my L69 305HO. I've found plenty on the FI ECM's but almost nothing on the carb'd ECM's.
Who out there with a carb is using the ALDL to get info from the ECM. I want to monitor some of the parameters (O2 sensor, TPS, etc) while I tune my car. Any help is greatly appreciated. Thanks and have a good one.
Old Jan 17, 2003 | 06:53 PM
Vader's Avatar
Sparkee,
Remember that the baud rate for communications on the older ECMs is only 160, instead of the 8192 rate of the later models. You're not going to get a lot of fresh data that way, but you'll get something.
I don't know of any scan software for them, but there must be something out there.
Old Jan 17, 2003 | 08:19 PM
ctandc's Avatar
Actually, do a search on Ebay for 'Brainmaster'. This is a scanner made by Alldata. You can usually pick one up cheap..like $30-50. It will give you all the data you need......TPS, O2 , RPM etc.
I've used these with alot of success on CCC Q-Jet cars.
HTH
Old Jan 21, 2003 | 12:19 PM
Sparkee's Avatar
I knew that it was the lower baud rate, slow data, but still better than nothing.
I'll have to check for that "Brainmaster" and see what I can find.
Thanks for the info.
69GTOby
Apr 18, 2016 02:34 PM
92projectcamaro
Dec 8, 2015 12:25 AM
1992Z28!
Nov 19, 2015 07:33 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
