headlights, foglights, blower motor, omg!
Old Jan 18, 2003 | 10:21 AM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
im needin some help locating wiring, and more so, where the relays are located on these cars. i have a climers manual, and it shows the relays, but its a close up pic, and i cant seem to locate em, they sure arent where most cars r, unless they've been previously riped out. right now i need help locating where the wiring oringinates for my wipers, foglights, and the relays for my headlights. my headlights wont close after i turn them on unless i pull the fuse and stick it back in. it is really anoying. allso, my blower motor wont turn on. used to it would if i hung a sharp left, any ideas, all help would be greatly appreciated.
Old Jan 18, 2003 | 07:55 PM
Car: '85 T/A
can someone pleeeeeeeeeeeeeaaaaaaaaaase help me out?!?
Old Jan 19, 2003 | 04:33 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
relay locations:
The foglights should be near the driver side firewall by the ESC module and fuel pump relay. The headlight motor relays are on the inner fender wall forward of the strut towers. The headlight motor isolation relay is on the passenger side radiator baffle.
Old Jan 20, 2003 | 12:45 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Blower Motor
Sounds to me like your blower motor might have some bad brushes inside it. The motor itself is located on the firewall on the passenger side (near the A/C condenser can). Here's a little trick to tell : Turn your blower on, if nothing happens, take a ratchet or small hammer and tap the blower motor, if it turns on, then you have some brushes going bad. If that's the case, it's simple to replace them (mine was $25) with a new one from just about any local parts store.... Hope this helps.
Frozer!!!
Jan 19, 2024 04:55 PM
soarestransam
Sep 1, 2015 04:00 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
