tach/oil pressure not working
Old Jan 20, 2003 | 11:27 PM
the 'roc's Avatar
Hi I drive an 1986 IROC-Z Camaro. My question is, my tachometer and oil pressure guages recently stopped working. I think it may be an electrical problem but i'm not sure, they both stopped working at the same time. My oil pressure doesn't even read, it sits well below red. I know the pressure reading isn't correct. I was wondering if anyone else has had this problem, or may know whats causing it. Thanks
Old Jan 27, 2003 | 08:35 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
You probably have a defective oil pressure sending unit. Its a small cylinder right near the oil filter. If you replace it, itll more than likely solve your problem.
Old Jan 28, 2003 | 10:17 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
its gonan be a bitch to replace. you are going to need to buy a sending unit remover tool.. its so hard to get a wrench in there... i bought the tool used it and took it back said it didnt fit.
Old Feb 13, 2003 | 07:21 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
If your tach AND oil pressure gauge died at the same time then don't go looking at the sending unit. Check fuses first, if all are good pull your cluster out and check the condition of your printed circuit. This plastic sheet conducts juice to your gauges and instrument bulbs and sometimes gets damaged or burnt.
good luck
92camaroJoe
Jul 29, 2023 07:57 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
