'87 digital dash in a '91
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Yes, we can make anything fit in a F-body...
It would be (i think) a wiring nightmare. It might fit fine, but would most likely require different wiring and possably different sender units (Espacilly if your current spedo is cable driven)
Check with Dakoda Digital, they would be able to tell you. Cant remember the web address though.
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Digital dash
couple questions:
First, do you have the digital dash out of the 87?
Second, what engines are in the '87 and the '91?
(reason I'm asking is v6 and v8 use different tachs, if you use a v6 tach on a v8 and vice versa, you will get incorrect readings unless you change the senders)
