Headlight Problems
Old Jan 30, 2003 | 07:00 PM
Eat_um_up's Avatar
Headlight Problems
My headlights wont go up. I have determind tha it is a relay that tells the lights weather to go up or down. But i cant find the relay.. can anyone help me? Maybe even have a picture of the relay? I am 100% sure its not the motor. the motor isnt getting power for the up mode
Thanks in advance
James
Old Jan 30, 2003 | 07:28 PM
llvll4l2c91350's Avatar
The headlight module or relay on the Firebirds is attached to the firewall near the wiper module assembly. It's a black square box and controls the up/down movement of the headlights. They do go bad often.
Old Jan 30, 2003 | 07:56 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
It's a '85 right?
If so, he has the older 3 wire style motors. The module isn't on his system.
The relay that contols the up motion is on the passenger side radiator baffle. If you have a TPI engine, its where the air cleaner box is. You'll have to take it off to see. Its bolted to the support. Someone could have moved it around before so look basically in thet corner where the charcoal canister is. It should be in that corner only closer to the radiator.
The relay itself looks like any other relay. It isn't like any other relay though. It cannot be swapped with any other.
Hope this helps,
Matt
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
