headlight relay
Old Feb 3, 2003 | 02:22 PM
2birds40's Avatar
headlight relay
where is the headlight relay for the drivers side 87 firebird
Old Feb 3, 2003 | 06:56 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Your car doesn't have relays, headlight motor functions are controlled by a computer module located near the firewall.
Matt
Old Feb 3, 2003 | 07:13 PM
2birds40's Avatar
then what would couse just the drivers side light to not work the motor doesnt work at all
Old Feb 3, 2003 | 07:17 PM
Matto'85TA's Avatar
The motor itself may be bad. The module can break/malfunction in a way that only one side works. Check to see if the motor itself is shot. If can hear it running when the lights are on then its stripped out.
Old Feb 11, 2003 | 12:25 AM
2birds40's Avatar
so where is this computer and how do i check it thanks
Old Feb 11, 2003 | 07:04 PM
Matto'85TA's Avatar
It should be near the brake booster, near the fuel pump relay, MAF relays, by the driver side firewall. I'm not sure how to check it. I hear it seems to go bad easily though. I have a '85 with the relay stlye so I don't hve to deal with it. Best way is to make sure the motors are good and the wiring is good. Check the fusible links. Make sure there is power at the red wires at all times (+12 volts)
Hope this helps,
Matt
Old Feb 11, 2003 | 09:37 PM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
so if i am not going computer controlled then the headlight motors wont raise? well my lights come on but they wont raise? whats up?
Old Feb 12, 2003 | 05:48 PM
Matto'85TA's Avatar
'82-'86 models used a relay system.
The headlight motors on the '87-'92 models used a control module to control the motors. Without the module working properly the motors won't work. The '87-'92 motors are also prone to breaking down themselves. The nylon gearing or the bushings will break and the motor will cease to operate. All you'll get is the motor making a wining noise as it trys to move the headlight up or down.
Old Feb 13, 2003 | 06:24 PM
Car: 1991 Camaro RS
Engine: 305 TBI
well i dont have a noise when i turn the switch on and they both worked when I started tearing into the car.
wheres this module and how will i be able to check it?
Old Feb 13, 2003 | 06:49 PM
Matto'85TA's Avatar
It should be near the brake booster, near the fuel pump relay, on the driver side firewall. I'm not sure how to check it. I hear it seems to go bad easily though. I have a '85 with the relay style so I don't hve to deal with it. Best way is to make sure the motors are good and the wiring is good. Check the fusible links. Make sure there is power at the red wires at all times (+12 volts)
Hope this helps,
Matt
Old Feb 13, 2003 | 07:31 PM
jakanc's Avatar
The headlight door contol module has two fuseable links inside on the control board. I had one blown a couple of years ago and the passenger light door stopped working. I repaired that and just the other day the drivers side stopped working and the other fusable link had blown. I found a used control module on E-Bay and that fixed the problem.
Old Feb 15, 2003 | 11:35 AM
2vmodular's Avatar
perhaps a wiring diagram would help:
http://www.p71interceptor.com/thirdg...lampdoor87.jpg
thunder57
Nov 7, 2015 02:28 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
